slowstang88
- March 15, 2012
- las vegas
- 1999 Mountineer 5.0
Well I'm posting here because my Mounty is slightly modded (welded thrush chambered muffler, 2 into 1 with 3" side pipe, and swiss cheesed lower air box). I bought the truck with 60,000 miles running really rough, poor idle, long cranking times, popping/sputtering/backfire through intake. I pulled codes and there were a lot and also tested fuel pressure which was extremely low (10psi KOEO). Replaced the fuel pump and cleared codes and CEL popped back on, was running 100% better but still not right. I got codes for IAT sensor out of range, oil pressure switch was also inop, and the ECT was also bad. Replaced the IAT/MAF, both of the other sensors and ran perfect! Well the modding bug bit so I hole sawed holes in the lower air filter box, ran even better and gave me a nice howl at 1/2-WOT but wanted more.. I was gonna get a Flowmaster but my buddy had a Thrush welded muffler on his truck and sounded good (and 1/2 the cost so i got one and cut off the catback exhaust and welded it on and made a 3" single out turned out the passenger side. About 3 weeks later it started acting like a dirty MAF so I took it out and cleaned it. Ran good for a couple weeks then one day started popping and missing off idle but past about 5mph ran fine, CEL came on again (lean bank 1, lean bank 2), re-checked fuel pressure which was fine, cleaned MAF again and cleared codes and took on a 20 mile drive. Standing acceleration was fine, but above 3000rpm started bucking lightly and had a hard time accelerating. I hooked up a Snap-on Modis and did a few functional tests (TPS voltage sweep, cylinder contribution test, watched o2 sensors, etc and everything was fine. Ran good for another week then CEL popped back up but with no driveability problems. pulled codes and got lean bank1 and 2 again and checked for vacuum leaks with carb cleaner, found one on the back of the engine. i replaced every brittle vacuum line with rubber (and tied them out of the way) and got ahold of the PCV valve which was only half in the gromett. Replaced the gromett and PCV and all was good for another week (till this morning). Cold start, hunting idle, 1100-500 for about 5 minutes until it warmed up. Hit the hiway and power was WAY down at 70mph, would downshift 2 gears to keep up so i pulled over and unplugged the MAF to fatten it up in case it was lean and it ran fine. No CEL, I'm getting tired of this damn thing...
So far I've replaced:
Fuel pump assembly
MAF
ECT
Plugs/wires/tested coil packs
Oil pressure switch
Muffler
Oil/oil filter/air filter
I did talk to the previous owner and he said his "mechanic" friend tried adjusting the timing and pointed at the cam position sensor, replaced the fuel pump (and didn't use fuel hose, which rotted out and caused fuel pressure loss). I'm about to park this thing, it's getting old having to think about it blowing up on my 50 mile drive to and from work...
Fuel pump assembly
MAF
ECT
Oil pressure switch
Muffler
