If you have "inspections" that actually check exhaust setups, it will probably fail (like you said, ask a cop/inspector to be certain). In most states that check such things (like VA), the tailpipe has to go beyond the rear door.
edit: yes, it will be louder. I have had rust holes quite far past the muffler, and you could hear the difference. I can't even imagine a hacked pipe just beyond a FM40, the sound/resinance from such a setup should be the equivalent to Chinesse water torture.
I just put a Flowmaster 40 on my X as a matter of fact. It has a nice rumble to it now, but I want the LOUDNESS. If I were to dump my exhaust, how much louder will it make it? Does it sound good?
I'm guessing you meant there should not be a problem, so i think im gonna just make the cut and maybe buy a turndown tip to help direct the Carbon monoxide.
Just to update whether or not it is legal, when i called the inspector he seemed a little unsure of an answer. He said on an SUV the exhaust needs to exit in the back of the vehicle but then i asked about if it were to come out the side before the rear tire. His answer: he knows its legal on trucks, but isnt entirely sure on SUVs. He gave me a number to call (closed on sundays) so i will call the makers of the laws tomorrow. If it is illegal im thinking that i can make it where i can just clamp on and off my current pipe and the turn down.
Well I cut the pipe yesterday about 5 inches back from the muffler. It's noticably louder and a bit faster. I cut it about half an inch behind the rear passenger door and am going to put a turn down tip on it.
