shane10
- February 9, 2016
- MW
- 2002 Explorer XLS
4WD
Hey all, planning on replacing both valve cover gaskets due to a leak, as well as intake manifold gaskets since I'll have it off. Not too worried about the whole thing besides the EGR pipe, I've sprayed it down with pb blaster a few times so hopefully it should come off easy.
While I have everything off I was also thinking about replacing exhaust manifold gaskets since I will have a lot of open room to work with everything else removed.
While inspecting everything I noticed that the rear most drivers side exhaust manifold stud/nut was broken off flush with the manifold, I was wondering the process to extract this, will a simple vice grip work, assuming there is enough bolt left to grab onto? I don't know of any exhaust leaks so I'm a bit apprehensive to even start, but am at 200k miles so figure it's probably wise to change the gaskets out
And tips/recommendations are appreciated, thanks.
EDIT: 02' 4.0 XLS
EDIT: 02' 4.0 XLS
