Ronin8002
- March 23, 2003
- Virginia
- 2008 XLT Ironman
I had my headers and exhaust done a few weeks ago but never got around to taking pics. I will post a sound clip as soon as I can find a recording device that does it justice. The headers are ceramic coated JBA's which feed into 2 inch secondaries and then join into a single 3" pipe, through a 3 inch cat, and a 3" single inlet dual 2.5 inch outlet Flowmaster super 40. The wrapping is DEI exhaust wrap sprayed with hi temp silicone sealeant...helps control heat down there and keep the heat in a little to help offset overcooling of the exhaust gases at low RPMs. Overcooled exhaust gases reduce low end torque so theoretically keeping them a little hotter helps keep good torque in the low RPM range. I don't know if it makes a huge difference or not. I do know that at idle exhaust flow is good enough to blow leaves and dust around 3 feet from the end of the pipes....so at least I know it's not restrictive!
