Aliceinchainsaw
- October 20, 2018
- 2001 Ford Explorer XLS
Hey there, long time lurker first time poster.
I am in a lurch and it's a bit of a story but I'll try to sum it all up. Here is a little about my X.
2001 Explorer XLS with < 260,000 on it.
This all started from what I thought were bad front wheel bearings and a very unsettling movement in the steering. I initially replaced both front wheel hub bearings as well as the upper control arms on both sides. (I don't know if they were bad yet but they soon would be as I noticed the boots were torn).
Test drive and it's 85% better except for a HOWLING from the back.
Rear end driver side wheel (99% certain it was bad bearing). I thought about this long and hard because I know how tough they are to deal with. It wasn't something I felt comfortable tackling so I looked into having a shop do it. (We all know how expensive that is..) I wasn't keen on paying that much for it because of the mileage on the thing and my concern was a month later the passenger side would start going out, etc.
Sooo... after much internal debate, I decided perhaps I should just get a whole different axle assembly and solve many problems at once. I was torn between a re-manufactured and a used one with a 5 year warranty. Well, I chose to go with the used because it was about $500 cheaper. (Hindsight.... sigh).
As I began this process, I realized that if I was doing the axle assembly than it would be wise to replace the shocks, u-bolt mounts, leaf spring shackles, bushings, since I am in there anyway.
So I did all of those. Then I get the new axle installed. (Note: Axle is 45 - 8.8 3.55 ratio)
My first test drive of it was less than a block. The passenger rear wheel bearing is fried from what I can tell. It was grinding something awful and when I got it back in the garage and hand spun that wheel and I can almost feel the gears clicking as it spins. "dunk-dunk-dunk-dunk-dunk". I don't know what else it would be other than a bad bearing.
I go and do some reviews and find out the company I bought this from is notorious for supplying junkyard garbage to people.... great. So I will need to deal with that.
Here is where I am at now though... What is the most logical way of getting this resolved now for the cheapest? I'm literally trying to close on my house November 2nd, so I am strapped.
I have my old axle assembly sitting in the corner of the garage. I know nothing about differentials or gears or pinions or any of that. However, it's definitely more accessible than it was on the car... Do I go about removing both sides and replacing those bearings out somehow and then putting it all back together and swapping it back in?
That seems like the best plan to me but I haven't the foggiest on where to even start.. I found a few tutorials but the pics are long gone. :/
Half of this was a vent.. sorry. Hah.
Thanks in advance for any advice.
