........Perhaps I should change the wheel bearings first and see if the noise goes away. If it doesn't, then I could look into a differential rebuild kit. Between doing the bearing replacement and the differential rebuild, maybe I'll just change the oil in the differential housing.
What do you think?
Thanks for your help!!
This is a 2nd. Generation, right? Solid axles, rear, with outboard bearings totally different from the front, especially if 4WD. Whine present only when power is being delivered to the rear wheels, not during coasting at no throttle? Rule out pinion gear bearings, rear wheel bearings, but not differential side bearings, although they generally do not fail in such a way as to cause
gear whine. IMO, the 2 BEST things to do are:
1. Run the vehicle while up on jack stands, have someone apply brakes while speedo indicates about 20-30, to simulate road loading, while you listen with a stethoscope to the CENTER SECTION of the axle assembly and the outboard ends of the axle tubes, where the wheel bearings are located. Careful listening can locate the place originating the whine. If noise is in the CENTER,
2. Remove the center cover plate, wipe off carefully several successive sets of ring gear teeth, looking for ANY surface condition other than bright, shiny, mirror-like on the tooth surfaces. The narrower, smaller surfaces are the DRIVE SIDE. They would be responsible for the whine, if surface finish damaged. If bright & shiny, they might STILL be responsible, if MISALIGNMENT has occurred due to differential side bearing failure. This would indicate time to check
tooth contact pattern. This can be done easily from under the vehicle, by hand, with driveshaft removed, wheels off the ground, cover plate removed, spray degreaser on gear teeth until rotation back & forth of the ring gear's several adjacent teeth to engage pinion gear teeth, remain clean & oil-free. Then apply Prussian Blue cream lightly to several successive drive and coast ring gear teeth, rotate back and forth into mesh with pinion, then look at where the pinion teeth have "wiped" away the blue stuff off the ring gear teeth. Good patterns are centered, or only slightly offset towards outside. If pattern, especially on DRIVE SIDE, is way off of acceptable, but tooth finish is shiny and nice, likely diff bearings are at fault.
If this procedure seems difficult to understand, don't hesitate to ask further questions. I have been diagnosing & repairing hypoid gears for 50 years. imp
