KayGee
- March 27, 2017
- Farmington, MI
- '16 & '17 PIU
Are you talking about this sheet -> https://www.icloud.com/numbers/0AtiYU-yJ4Nrfyfuzp-Mi0l8A#FORScan_2011-2018_Explorers ?I just followed the Platinum Owners spreadsheet and those were the modifications listed, I'm not sure if all of the bits actually needed to be changed.
Maybe @PlatinumOwner can clarify.
That one just lists dark car as a single change to 726-32-01 which doesn't seem to work for all Explorers (may not work for any Explorer?).
I didn't look through every tab, but the change to 726-58-02 isn't even listed on the common or interceptor utility tabs at all. Based on my experience, both were necessary to enable "dark car" on my PIU.
I've tried out quite a few different changes on the interceptor utility tab that did seem to work as indicated (ex: AWD gauge & avg speed/RPM on my PIU, the only 2 options that worked were disabled or enabled - the other two options just messed up the dash display by causing the fuel gauge to read empty). That line shows it was tested and confirmed just like the dark car line, but there is obviously something more to it if some of the changes don't really work on all PIUs/Explorers. Just my 2 cents...
