Explorer door striker pin | Ford Explorer Forums
Max Sharratt
Brasilia, Distrito Federal
1997 V6 4x2 manual change
Do I need to replace the whole door striker assembly if the plastic sleeve on the pin has disintegrated? Where can I find these parts?
They carry the new latch assemblies in the "HELP" section at our US auto part stores, not sure about over there... They are about $7 for a new latch with new bushings already on them.
The loose sleeves they carry only fit the tailgate. I've not seen anyone carry the sleeves for the doors, and I just replaced two pins on my truck last week due to worn bushings...
T50 Torx bit, 5 minutes, and you're golden.
They would be like this:
CLICK ME
pin bushings gone
would those pictured pins be the same for the liftgate as well as the doors? all mine are gone all the way around and liftgate wont close right i have to close it with both hands on either corner and slam it hard!!!
If you have the pins but no bushings on the pins for your liftgate, you can get the sleeve replacement kit in the help! section. I would go to the sherman website and run the part numbers for the liftgate assemblies to be sure if you need the entire pin. I replaced the bushings on the liftgate of my old '95, so I know the refill kit works for them... :thumbsup:
tailgate striker pin and bushings
In numerous part suppliers on-line catalogues I didn´t locate the pin assembly which was confirmed as the part for a 1997 4x2 manual change. One or two looked right but they told me it wasn´t the right unit for my vehicle. Also I was nervous about the retaining bolt slipping inside the body, ie the problem going from bad to worse. For now I have fashioned bushes from the plastic caps of a 20 litre water container and secured them with insulating tape. Not pretty but it works. I´ll probably need to repeat the process in a year but so what.
I tell you what, I will look for one here and see how much it will cost me to ship it to you if you PM me your address, I will ship it to you at no cost to you as long as the shipping is reasonable.
You just need the striker right? It comes with the plastic sleeve as a kit.
And you are talking about your 97 Explorer, correct?
striker fixed
Okay so I went to autozone last night and got a striker setup from the help! section and it fit perfect but the 2nd one I bought today(only bought one last night to make sure it would fit right) was a larger diameter bolt so what I did was just take the sleeve off the new one and put it on the old striker so problem is now fixed. also i got the sleeve replace kit(2lrg/2sml sleeves @ 3.99 instead of 8.99 for one striker assembly) and just replaced the sleeves on the liftgate strikers. all fits well and closes nicely but take note: **The brackets behind the tail lights only has 3 fins holding it in place and they bend very easy when trying to remove the liftgate strikers so be careful not to break them off in the replacement process** I just used a pair of vice grips to hold the bracket.
Dear 96xplorer4OH Thank you for your kind offer. As I need parts for all doors and the tailgate (in reality only the plastic sleeves but we know these are not sold separately) if you have time to locate a supplier (email7phone7address) where I can obtain the strikers for my 97/97 4x2 manual V6 I´ll get in contact with him and see if he will freight to me. I still worry about how easy it will be to replace the strikers given the fragile brackets securing them as Juggaloscorpio says. Removing the lighting assembly will give access to the tailgate strikers but for the doors?
Anyway, nice to hear from you guys, I love my Explorer which I bought in 2002 with 62000km from a single owner and now I am approaching 160000km. There are still a few lowish mileage 90s Explorers available mainly in Sao Paulo state. Beats the hell out of the Japanese and Korean SUVs which are tremendously popular here. God bless America especially Willie, Emmylou and JerryJeff.
actually autozone does sell just the sleeves for the tailgate but not the door strikers (4pk $3.99 and 2 are not for explorer use but 2lrg ones work for liftgate)
the brackets are sturdy but the fins that hold the bracket in place are not and I think removal of the interior trim where seatbelt is secured(please correct me if im wrong havent tried it yet) should allow access to the brackets for the door and if you use some PB blaster on the brackets the strikers will come right out
Autozone's Help! access. section does have 2 different striker kits for the explorers($8.99 each) make sure you get the one accordingly as I didnt and got the larger bolted one(last one on rack) and wasnt paying attention to it on install and stripped the bracket out but was able to re-install the old striker(by crossthreading it unfortunately) and am now dealing without a sleeve until i can replace the bracket also
