2stroke
- August 7, 2013
- Location
- 57401
- Aberdeen, South Dakota
- 1993 Ford Explorer Sport
Well with my 94 explorer pretty well gone for road use, and my 2002 mercury cougar being a car, I traded the cougar for a good condition 94 mazda b4000. The car had minor transmission problems, and some other issues, but was otherwise perfectly reliable. This truck has a perfect transmission, but runs a little rough, but is also perfectly reliable. Plus I have the explorer for parts. Here's the thing, the truck engine was replaced with an explorer's engine which has 160,000 miles on it. The stock one was the same thing anyway, so I figured I would ask here.
Anyway, here is the problem as I know it now. At idle it has miss, and it is fairly consistent. Whether hot or cold, it idles on 5 cylinders, and rarely clears out. When cold, the engine almost always has a miss when driving. When the engine warms up, it starts to clear out. Sometimes it runs great for a minute, then, sometimes it misses and clears out at above 2000 rpm, sometimes it always misses. It has a normal idle rpm, never stalls, and otherwise runs good. Gas mileage is poor. I'm not sure what it is, but I have about 120 miles on it, and the tank is 2/3 gone. My guess is around 12 mpg. What I do know is that there is very possibly a vacuum leak, and sometimes I can hear it, but never at idle. It doesn't seem to affect how it runs when I hear it. The EGR was deleted, and I have a feeling that vaccume sound I hear could be the egr trying to open. It still has the valve and other components. The pipe rusted off, and both ends were blocked off. An aftermarket air intake was installed, and I may put it back to stock. I don't see how it would do anything as it's not installed as a cold air intake. Spark plug wires are new, coil is new, spark plugs are new, but with the NGK iridium. I would much rather have standard NGK $2 a plug ones, but I don't see how iridium would cause a problem like this.
The check engine light has come on. I was told it was for an O2 sensor. When I put in my radio, I disconnected the batter, and all memory was erased. The check engine light has not come back since for me to check it. I suppose now would be a good time to ask that these trucks can uses the "paper clip" method to check codes just like an explorer. I have thrown around the idea of a dirty fuel injector, but I would think that would cause a totally dead cylinder.
I guess the real question as I wait for the check engine light to come back on is could an 02 sensor (or both) cause a problem like this?
Also, as cheapo as this sounds, what do you guys think of "universal" O2 sensors. I am at a very poor point in life right now, and cost is a huge factor. I can't get OEM, and even parts store bosch is $50 each. On Ebay, I can bet bosch for $25 buck each, and I may go that route. Also on the bay, I found a brand I have never heard of for $13 each. At that price I could easily replace both.
