Explorer Express Air Dam Install | Ford Explorer Forums
aldive
Elite In Memoriam
1999 XLT
The Explorer Express Air Dam for the 99 Explorer is now installed on my truck.
This was a simple install and required few tools; a drill and a bit ( sorry, I couldn’t read the size on it – but the size of a # 6 bolt, flat blade screwdriver 5/16” wrench, a 3/8” ratchet and a 7 mm socket.
After re-glassing the dinged up air dam, sanding and painting ( I decided to try to match the color of the dark grayish black “bumper” as close as I could – and it matches quite well ), it was time to do the install.
The ends of the air dam are mounted to the bottom of the chrome surround for the factory fog lights using the existing 2 bolts ( on each side ) that hold the chrome piece to the plastic “bumper”. The air dam is very light and can easily be installed by one person without the need for supports..
On the air dam there are indentations where it needs to be drilled for these bolts. After drilling and reattaching each end with the old bolts. The fit is exceptional. Then, a hole was drilled through the air dam and the plastic “bumper” in 6 evenly spaced places along the air dam. One inch # 6 bolts with # 8 flat washers, a lock washer and nut were screwed down.
That’s it; a very simple install. Pictures soon, the digital camera decided to crap out.
Time involved was about 8 hours for the glasswork and painting ( 3 coats ), including sanding and drying time; the actual install took about 30 minutes.
Mine looks just like this picture from Explorer Express…..
Sounds pretty straightforward except for the glass work & paint.
Now get us some pics........Oh ya, get it lowered too...
Bill, I will be ordering the Explorer express lowering kit, the special Edelbrock shocks and the bigger sway bar as soon as I return from a trip to GA to check on the ranch and visit friends.
Pictures soon....
Here it is....
Thanks for the pix. Looks really good.
aldive.. can u post future gas mileage improvements if tehre are any? i think i remember someone mentioning 1-2 mpg increase after installing the EE airdam.. wondering if you could confirm that. thanks
I have picked up an average of 1.5 MPG at highway speeds with the air dam.
sorry to ask this stupid question, but i couldnt find it on the EE website. do u think u can post the link to the page where u found it?
Its in their printed catalog. Call or E Mail them to order it.
Good luck.....
It sorta hidden in the EE website, for some reason they put the airdams in the "interior" section. BTW if you order something from them they'll give you a catalogue free, which is sometimes better than their online catalogue.
They do not list the X Spec air dam for the '99 in their on line cata;og for some unknown reason.
Originally posted by alphasylum
Aldive....can you post some more angles and farther away?? I'd like to get the whole picture.
Here are a few more shots....
another view....
another view....
alpha... dont you have a 98? Aldives airdam will only work on 99-00.
They also make an X-Spec airdam for 95-98's as well.
yeah but it looks totally different and you need some sort of fog/driving lights to go with it.
