FourBinLabs
- January 10, 2013
- SW Michigan
- Mercury Mountaineer
Ok, this one caught me by surprise.
My 00 Mountaineer had two bad axle seals and had metal chunks stuck to the magnetic plug every time i pulled it to add 80-90 to it. The LSD was also shot so I found a 99-01 explorer with another 3.73 LSD in it back in march and pulled the axle. I wish I knew the exact year on the donor vehicle, but I'm not sure if it would still be there now.
I just put the axle in last night. Everything went smooth enough, but when I went to attach the... I guess we'll call them trailing arms... There were no tabs on the axle to attach them to.
So my question is... These arms that are connected to the frame via a bracket, then go backward toward the axle to connect to the top of the axle. What are they? Is this a handling improvement made to the mountaineer but not the explorer, or is it something they added after the firestone rollover lawsuit?
I removed the passenger arm for now, and have tied up the driver side arm which will be harder to remove. I'd like to find out if I should find a way to weld tabs to my "new" axle, or just remove these arms and not worry about it.
