mikey67156
- November 9, 2009
- Winfield KS
Specs: 1992 Ranger 4.0l Manual trans 2WD.
Long post. Sorry but I wanted it all out there.
About a month ago the pickup started running rough. Just a rough inconsistent idle, and weak throttle response (no CEL). This was coupled with a corroded freeze plug on drivers side rear cyl. head. At this point I decided that because I had leaky valve cover gaskets and no cherry picker that I would just remove the cylinder head and change the freeze plug that way.
Everything went back together nicely. Upon first start I realized that the engine now runs like well... crap. uopn cranking engine starts revs about a second, then without help it dies. If you bump the gas it stays running, but only with constant throttle nudging, and still just barely stays running. After about 10 minutes of babying it, it runs on its own, albeit with a high idle. Could it be that the PCM has a null setting, and it just doesn't mesh till it warms up?
Checked sparkplug wire order according to the (terrible) pic in the Haynes Manual they seem right
Had 4 different guys do a flashlight exam for disconnected wires (hey it happens)
Ether tested vacuum lines
Performed KOEO got 34. Continuous memory showed 157, 158, 543, 556. I was unplugging MAF earlier while it was running.
KOER 173, 411, 412. Cylynder balance test was impossible to run because of the erratic idle (the ONE I really wanted to run.
Components checked: Ohms/Volts respectively. MAF, IAC, TPS, IAT (showed bad, replaced no change in performance) Feul pressure regulator, stethoscoped injectors they sounded fine, nice steady rhythm that is.
I'm baffled I'm a 4.9l guy. Usually you just throw an IAC at it and your back down the road.
Thanks for any help,
Mikey
Mikey
