f-150 coil SPACES please read----> | Ford Explorer Forums
Trapper14
Horseheads, NY
91 xl 2dr
I just stopped by ford and I ordered them, although I wasn't sure what to order, so I ordered the left and right top spacer.... was this correct or should I give them a call?
Thanks
I think you want spring seats, that go on the bottom, thats what I have. There are several post that have the partnumbers, do a search. I don't know if the top spring spacers will work or not.
i DID A SEARCH BUT COULDN'T FIND ANYTHING.... DAMN! i should of order the bottoms ones....
don't worry about it, see if the top ones work, the bottom ones are only $30 if you need them.
Hey trapper , I found these in a search
F2TZ5A307A Ford Coil Spring spacer $13.99 ea
F2TZ5A307B Ford Coil Spring spacer $13.99 ea
Good luck.
How much lift do the coil spacers give you? Is there one that is only 1 inch?
Thanks.
I got about an inch, maybe 1.25" out of those F-150 spring seats. Toad has the part number right, get em at your ford dealership.
I thought you could get a 1" or a 1.5". You can always have a machine shop make them for you in the size you want.
okI received the front top spacers today, and I was wondering if the bototm ones looked similar since I don't want to order new ones, they sorta go from thinner to thick sorta like a coil would do,, it this right?
Thanks!~
If not I work in a machine shop as a student and could do it out of aluminum!
Trapper, let me know how they worked out!!
Im thinking about doing that also but know that i saw byrd mention spring seats, I want to see which are better.
Thanks
ok I will, I just hope they work! I am thinking of ordering the bottom ones just in case, because I don't wanna be in the middle of installation and have it NOT work, that woud really suck!
Or try and make some aluminum spacers in the machine shop
