f150 spacers | Ford Explorer Forums
f150 spacers
91navjo
richmond va
92 explorer sport 4x4
hi everyone!! newbie here i want to do the lift with f150 spacers and the warrior shackles?? whats the part numbers for each of them and where to obtian the shackles?? after doing this will i be able to fit 30's under my navajo?? right now i am fixing all the common problems with the early x/navajo tranny plugs,vavle cover gaskets,lower intake gasket, new motor on t case, bearing and seals in the 8.8 .all the other problems that are common have been fixed. this truck has 85K on it and is clean , lots of new parts.... only paid 1500 for it.. sounds like a good start?? any suggestion welcome.
Welcome to the board. I just recieved my spacers last week. sadly I'm at work so I dont have the numbers handy. But if you use the search function there is TONS of discussions on this...
I had 30's on my ex when it was stock with no lift at all....worked fine
Dunno about the spacers, but the shackles are WAR153 and available through 4 wheel parts, about $50. You have to call them, they're not in their catalog. With the lift, 31's should fit easily.
