nak4af
- July 4, 2001
- Omaha, NE
- '16 Yukon, '20 F-Pace SVR
Just to let you know! Crutchfield has a wiring harnest that bypasses the factory amp for around $11.95. The hardest part is removing the panel. If you can find a small enough amp, you could install it where the factory one goes. I am wanting a 5 channel to run all speakers and my sub. I am using my factory amp 'cause its louder than the head unit output, but also has more noise at low volumes. It's a trade-off I guess!
I am planning to attempt to remove my rear washer reservoir and place an amp there. Only if I can get the rear wiper motor to work off of the front reservior! I use the rear of my truck WAY too much to put an amp back there. Hey, outta sight outa mind right! If it works I'll be able to access the amp VIA the jack access door. Well, sounds good in theory! Its just a matter of findng an amp with the right demensions!
To any avail...it's a never ending saga! Good luck CHINSK!
