vipersinu2
- March 10, 2008
- The Big City of Orange City, Florida
- 2019 Navigator 450hp
I bought a used 2003 explorer for 1500 bucks with 180,000 miles ( I put a new 2010 engine last week 2000 miles on it) fan clutch seems stuck on and seems like there is a bunch of power loss. It is hot here in florida about 80 at night and still on nostop whine from the fan. ( I took the fan off and whoa abunch more power!!) I noticed in the morning with the cool air it runs great! but i don't remember if I heard the fan or not. I will check tommorrow morning.
Is there a way repair clutch by spraying lube to loosen up clutch? a new fan is around 50 bucks or should I go with an electric fan?
I replaced engine
mass air flow ( check engine light was on)
throttle position sensor
soaked injectors in marvel oil and sprayed out with carb clean.
fuel filter (one half of the filter was clogged and dark brown dirty gas came out. what a pain in the ass job to replace that filter)
air filter, belts, and hoses
rear blend door actuator
things that need replaced
rear has loud whine (ordered one on ebay)
fresh air/ rec air door broken
upper ball joints boots torn but no play yet
steering u joint boot ripped also
for around 3200 bucks so far and a nice truck should last a bit!
I replaced engine
