fan speed switch problem | Ford Explorer Forums
stevengould46
Ranger '98
My Fan speed selector switch works on high only. Any other posotion is 'off'. I've replaced the switch, no change. Broken wire? Where to check next?
The most common cause is a failed blower resistor block next to the blower motor in the HVAC plenum. A replacement block costs about $12~18.
It's under your hood, passenger side on the firewall. I would take a picture but my camera crapped out.
Here's a picture I "borrowed" from another post. You can see the connector for the resistor right next to the blower motor.
