Rjj
- November 7, 2001
- Fox Valley, WI
- 94 Explorer XLT
Feeeeeeed UP with my 94 XLT 4.0L Explorer 69,000 miles
Always very poor gas mileage, knocks bad while going on the highway, engine light goes ON while driving on hwy...(usually after I let up on the gas), and cruise control is out (hoses plugged). This vehicle was under warranty when I purchased it and Ford miserably failed to fix the engine issues (poor gas mileage, slight knocking) and then 800 miles after the warranty expired...the front rotors were found to be destroyed, had to replace everything!
Ford told me the "engine wasn't getting upto temp", so they installed a higher temp thermostat. I just had the original one put back in. I believe the temp-sensor or something like that could be misreporting...hence the bad gas mileage (11mpg in the city).
I once had the plugs changed and that seemed to help for a while. I don't know if I want to spend anymore money on this lemon. The diagnostics are costly and no garage has figured it out to date. How can I diagnose the problem myself? I have a technical background. What do you recommend? I would appreciate any and all help!
SpeedSter240EFI
Rj
SpeedSter240EFI
Rj
