take a pic so people can see the extent of the rust . if you have the same thing I have which is just surface rust around the wheel and gas filler you can grind it out in 5 minutes with a grinder and bondo it . if you have a hole right through you may want to fiberglass it , I wouldn't do sheet metal work unless you want to make a show car or keep it for 10 years.
