arco777
- April 6, 2008
- 1994 Explorer 2dr 4x4
I also checked, and the spark plug on the drivers side near the front of the engine (radiator area) is disconnected. this is the one that my dad yanked to get it back in, "claiming" it ran better that way. not sure if that means anything to you guys. Looking in the haynes manual, it says that's the #4 cylinder, the one he thinks has a crack in the block possibly (his words, not mine)
Cylinder head cracks will often dump coolant into a cylinder, causing a misfire. You can often tell by looking at the plugs; an exceptionally clean plug with 5 other normally dirty ones is a good indicator. Perhaps #4 was indeed misfiring due to that, but cutting ignition to it wouldn't help things. Crack in the block is unlikely, crack in the head is likely. The head gasket will need to be replaced anyways but if the head is warped and/or cracked a gasket will only be a temporary fix. Quite a few people on this board with cracked heads have replaced head gaskets instead and only fixed the problem for about 1-3 months till the "gasket" blew again.
I don't believe the stock heads can be fixed for good, an aftermarket replacement is necessary. Some newer 4.0 OHV heads are known to be more reliable though not completely immune, but you could try a junkyard set of OHV heads from a second gen Explorer if you're on the cheap. The material used on the first gen heads is just bad and reman'd ones will eventually fail.
Parts lots like Pick-N-Pull often have pretty low prices and run sales all the time. You could get heads, motors, etc very cheaply there and with warranties. Worth a call.
