14" should work just fine. Tire or body lift size does not matter.
It also depends on where you install them. The farther out on the LCA, the better, and the longer they need to be. The closer to the frame, the shorter they need to be. Make sense? You can figure out how long you want them by measuring the full droop before you over extend the CV axles. Figure where you want to mount them. You then go a little shorter in length with the straps.
i have a 99 with the auto 4x4, if i do the brown wire mod would i be able to put an aussie in the front without worrying about it? lockers seem like the best 4x4 upgrade, i would really like to have them but my explorer is my daily driver so i need it to stay reliable.
