First time taking the explorer out. (pics) | Ford Explorer Forums
deanler
Sarnia Ontatio
96 Eddie Bauer
I've had my explorer out in an open space with mud but never actually had it in a bush or anything with hills and stuff... It was a good little trial run that showed the obvious weeknesses of the truck hahaha. Mainly due to lack of hieght but i made out alright
I just need to pic up a passenger mirror because i backed into a tree and i should be good to go. The valance with the fog lights is lost somewhere too but I'm not to worried about it
had to pull out my tard cousin with bald mud terrains that forgot to put his truck in 4wd
better look into extending the vent lines if you are gonna go into water like that many more times,,
better also check the diffs and trans and t case for water ,
but it looks like it was fun, good one pulling out the Chebby,,
What vent lines are you talking about? It probably wont happen much but extending some vent lines cant be to much work.. Also, how would water get in the t-case of diffs? If oil doesn't leak out how can water get in? Never had a 4wd before so I need sum learnin'
Thanks
there are vent lines on the front diff the rear diff the transfer case, and the trans,, they can get water in them , and it will run down from the top to the bottom, and not leak,,
