Fixed Truck now will not start | Page 4 | Ford Explorer Forums
If there is fuel pressure and power to the injectors, and no fuel is coming out, then it has to be the injectors... doesn't seem to make much sense that they could all be bad... but maybe they got messed up by the cleaning place :scratch:
Makes a whole lot of sense but for all of them to go bad at the same time? I think I'm going to have to go back in and pull the rail keeping the sensor's attached to see if they spray. But I would think this is clearly a fuel problem.
OK. Here is where I'm at.
The car will still fire on starter fluid. But will not run more then 3 secs. I'm conviced no fuel is getting into the cylinders.
I have had a positive result with the noid light but I back to the injectors and checked the voltage. I am only showing 2-3 volts. I'm thinking this may not be enough to gettng them flowing.
[*]I have seen the right voltage as anything from 6 to 12 volts. Can anyone confirm this?
[*]Could the lower voltage be the result of a bad ground?
[/LIST]
Anyone have any thoughts?
Thanks.
