nitrodude
- May 28, 2013
- 97 ford explorer
FYI: bad head gaskets don't leak oil. they leak coolant. your engine oil leak might be the pan gasket or valve cover gasket (if your lucky). it could also be the rear crankshaft seal if you see oil between the rear of the oil pan and the transmission bell housing - much bigger job.
The oil looks like its coming from the head gasket.
Could be the valve cover gasket though.
I just know the top o the 3rd cylinder header is coated in oil lol
