Flashing 4wd high & 4wd low | Ford Explorer Forums
vinson
Rothesay ,new brunswick, Canada
2002 4.0L EB 4X4
my 99 SOHC XLT has been flashing these at me for a couple of weeks now. The dealer does not know the problem.
the 4wd lights flash a few time then goes out for a few minutes and then a few more flashes, this is all the time.
the truck is auto 4wd and seems to engage itself when needed however when I turn the dial the to 4wd high the light will not come on ( it just continues to do the flashing thing) it will not go into low range either..
any thoughts????? :can:
a.) If you search you will find plenty of threads on this topic
b.) For a quick-fix, disconnect the battery for a few minutes, and then reconnect. If it is just an intermittent issue, this will clear the lights.
on my 97 I had to clean the sensor your 4wd will not lock in if they are flashing... if dirty I would clean and drain the t-case with new fluid... (merc 5 I beleive)
