Flashing 4x4 lights | Ford Explorer Forums
Flashing 4x4 lights
IndyExplorer
My 4x4 high and low lights flash simultaneously at about one minute intervals starting yesterday. I have a 98 Explorer XLT. Is anyone having this problem, or know the cause and how to fix it? Thanks!
Indy,
Let me ask you a few questions first, Do you have a Tire with Low Air Pressure? Does the Lights stop Flashing if you Cycle the Ignition Key? Time the Delay between the Long Pause's with a watch. I have had this same problem, and its comes and goes, I have found out from this site that it maybe a sensor in the Transmission that is either dirty, or broke. When my 4X4 lights flashed, I could time 2 minutes between the start of one flash cycle, to the start of another flash cycle Exactly. I would try to do a search and see what you come up with. But I have had a similar problem. Thats all i can tell you, I hope it helps.
[Edited by CBoug76 on 10-12-2000 at 06:18 AM]
