Flashing O/D Light:Read This Before Posting!!!!!!! | Ford Explorer Forums
xFatcatx
PORTLAND OREGON
99 SPORT
If your O/D light is flashing in your dash, this means you have an issue with your transmission, don't panic. The flashing O/D light is you "check engine" light for your transmission. Cheap scanners like the ones at most autoparts stores cannot pull these codes! If your overdrive light is flashing, stop by any transmission shop and they will 99% of the time pull the code for you for free. When you are at the transmission shop remember to:
1. Never leave your truck alone with them, they can come out to the parking lot with the scanner.
2. Stand there and watch the scanner, right down the codes yourself (P0741, P0742 Etc....). They just plug it in under your dash and start the truck.
3. Be nice and get a quote from them, they will most likely tell you that you need a $2000 rebuild, which may be the case but probably not likely unless you are having major issues.
4. If they tell you that you need to leave your truck with them or they need to pull it into the shop for this then just simply leave and tell em your going to the shop down the road.
5. Come back to this wonderful forum and post your code with your exact issues, year, make, model, milage, recent service, and anything else you may think could be helpful.
Will a moderator please sticky this to the top of this forum, granted some people dont read the stickys, it might save a lot of time and useless banter. Thank You
p.s. feel free to add or edit anything i missed.
If the codes are what youre after, I would recommend the scanner from http://www.obd-2.com. I have been working through a lot of transmission issues on my 97 and despirately needed to get the codes. (Some were caused by me when i did a rebuild and failed to get it back together properly and some were caused by wear and tear) I got the recommendation for the scanner from a forum member so i gave it a try.
Anyhow, the scanner is about $120 and will pull transmission codes. If you are not good with a computer you may need a friend to help you as it is not the most polished program out there.
This is very helpful ... I have the flashing o/d issue, then the service light came on. A friendly fellow from FORD did drive the 6km to my 2005 Ford Explorer LE, and he did use the computer gizmo ... I didn't see the code but he said that when he checked the book that he had with me ... it said the shift solonoid ... I don't mean to be rude but I never trust 90% of dealership people ... mechanics generally unless I really know them or they've been recommended to me. The fellow was nice ... gave me the phone number to another garage, telling me that everyone that works there are ex Ford mechanics ... I will check in the am .... at the dealership .. if they are going to try to charge me for anything ... yeah no thanks and I'll go to the other. This is a great forum! Glad I found it:)
