VirginiaMonkeys
- August 1, 2003
- Stafford, Virginia, USA
- 2000 XLT
Today I drove about 5 miles and then turned off the vehicle. After about 10 minutes I started it up again and it idled for about 10 minutes. I noticed the temperature guage was at the top as far right as it could go, and the check engine light was on.
As soon as I put the truck in gear and revved the engine to go, the guage dropped to the normal position.
If I drive down the road, the guage hits the top if I'm decellerating or at a contant speed. If I accelerate, the temperature guage drops to normal.
If it's idling in the driveway it won't change in N or P by giving the engine gas, but if I put it in gear with one foot on the brake and give it a bit of gas, the needle will drop some.
I just got done replacing the thermostat with a OEM spec one from AutoZone, and a new radiator cap (pressurized).
None of that has helped with this one.
Any ideas? Any diagnosis I can perform to find the problem?
Thanks.
Thanks.
