fluids for a tranny when replacing a clutch.... | Ford Explorer Forums
schmidlkofer
thornton, colorado.
94 XLT
what fluids do i need? if any.....
any one.
bump....im going to be getting the clutch today so what do i need.
Your tranny probably uses ATF.....
you dont change nothing unless you are chaning the tranny fluid. Since you have a 5speed the only other one is dextron three atf and the brake fluid for the master cylinder
so i use brake fluid for the clutch right? and how much do i need.
well ill just ask around town i guess......
You just fill it up. There is only so much you can put in there. There is a line on the little tank. Get some extra so yll have plenty when you bleed the clutch after you put the new one in.
thank you burns....
It takes time to get responce. It will happen sooner or later. Good luck.
