you dont change nothing unless you are chaning the tranny fluid. Since you have a 5speed the only other one is dextron three atf and the brake fluid for the master cylinder
You just fill it up. There is only so much you can put in there. There is a line on the little tank. Get some extra so yll have plenty when you bleed the clutch after you put the new one in.
