Flywheel Spacer? | Ford Explorer Forums
Flywheel Spacer?
ParkerRocker
Hayden, ID
92 Explorer Sport
I had my flywheel machined. 20/1000". Should I get a new wheel or should I just space it out? I'm installing it with a spacer so I hope that's what you guys suggest...
You shouldnt need a spacer (I didnt know spacers were even available). Two hundreths of an inch is almost insignificant compared to the stroke of the slave cylinder.
.020?
Where did you find a spacer that is .020? I'm thinking you didn't. And you might have problems getting the transmission to seat proplerly.
Ryan
As mentioned, you don't need a spacer for that amount of machining.
However, if you've taken enough material off a flywheel that it would need a spacer to work correctly....it's time for a new flywheel.
