Fog Lights for Xls 02 | Ford Explorer Forums
prol
Stgo
02 xls
So i just bought a Explorer xls 02 .......its 4x2.......v6 4.0 , Ok so my question I wish to install some foglights....How do i go about this .......i would like for it to look stock .......Any help would be great ....o and Hi !!!!!!!!
Welcome to the forum! There is a lot of helpful threads on this site to show you how to install all kinds of lights.
prol.... have you ever figured out how to get some fog lights to look stock for your XLS..... i also have an xls and was wondering the same thing, if you did please post a pic and which fogs did you use
You could probably find the factory foglights on ebay, but you will have to do some custom wiring. You could wire it with our without a relay. If you use a relay you could mount it under the hood somewhere. You can use just about any 12V source to turn on the relay. Run a wire from a switch in the truck to the relay. Positive from battery to relay and from relay to lights. You can ground the lights on the relay or at the closest point by the foglight. You might want to get a relay socket as it comes with wires already and it helps a bunch.
