Coke734
- January 19, 2003
- Just outside Detroit, Michigan
- 1999 Explorer Sport
I've been told that it is necessary for two things to be done after lowering the front of my 1999 Sport by torsion bar adjuster twist; 1) alignment, and 2) camber adjusters... what exactly are camber adjusters, where can I get them, and what do they do? (are they absolutely necessary?)
Also, I have already dropped the rear approximately 1 3/4" and I'd like to even the front out to the same height. Using the measurements I took before lowering the rear, I would need to lower the front driver's side 2 3/4" and the passenger's side 2 1/2"... I checked my torsion bar rating and the bars are rated 'H'... does anyone know whether I will be able to drop the front as far as I need to by using the twist?
