ford 9 inch, what spline? | Ford Explorer Forums
351wExplorer
michigan
94 sport
how can you tell what spline you have in a ford 9 inch, without pulling it apart, heres a pic of my 9 inch. any help will be appreciated
Do you know what it came out of?
im almost positive it was a 79 bronco
does anybody recognize that rearend, i mean i havent seen many fully welded in the back like that?
After looking at your pic again, it is obvious that that 9" is a "non-banjo" type of 9", which means there is no way that it was factory in '79. The non-banjo is a less desirable axle than the banjo style 9".
I will have to take back my prediction that it is 31 spline, but I will have to leave this to those that know more about nines than I do.
1st pic........banjo (late model) 9"
2nd pic.......non-banjo, earlier, 9"
edit: I am COMPLETELY backwards here. Yours IS a banjo style, and the other isn't.....................my goodness, I am WAY OFF TODAY!!!! :rolleyes:
Oh, and about the welding in the back............if you mean how it is welded where most rears would have a diff cover, then yes, that is typical of all Ford 9"s.
why are they less desireable besides the fact that the axle shafts appear thinner and if not out of a 79 bronc , does anyone have any idea what it would have been in?
so since you were backwards does this mean that it is possible it is out of a 79 bronc and is a 31 spline?
31 spline, definatley a 31 spline.........Kmart sucks..........
did i miss somthing with the kmart?
Rainman, get it? Nevermind, if it's an EB, then it could be a 28. If it's a 78-79, it's a 31.
