ford explorer 2004 won't turn over | Ford Explorer Forums
frylockxxx
white lake mi
2004 explorer
Not sure where to start any help or suggestions would help. For starters originally this weekend was planned to take a look at my wife's multi-functional switch because when ever she would use her left signal it randomly started to make a buzzing sound when ever it was on. Not sure why that is happening but it is probably stemming from the front left turn signal being broken for a while.
On Friday we went out to go grocery shopping and took her car because she said she needed gas. We made it less then a mile down the road and ran out of gas. ( I walked and got us some gas. Car started up fine we went shopping and came back home.
Saturday morning came around and i decided to get going on the original problem with the buzzing. when searching this forum i read that my switch may be dusty and need a can of air sprayed in the hazards button and but the multinational switch. so i sprayed the air, cleaned the battery terminals, checked some fuses from the power distribution box under the hood, and pushed the hazard button a few times. I went to turn on the car so i could check the turn signal. and the car wouldn't start. dint sound like it was turning over at all just clicking like a dead battery. also strange that it kept sounding like the hazards were on for a little bit. when i tested the battery my simple tester said weak on load bearing and without load it had 12v. tried charging and jumping. it didnt work. waited for wife to get home with other car.
Sunday(today) I took the battery to auto zone they said battery was good and was at 80 percent. they charged it for me taking way longer then they expected around an hour and 40 minutes. got home and hooked up battery and tested with no luck in turning over the engine...
I am usually good at searching to find my issues but i am stumped with many different variables any input is appreciated
Update when key is in it makes a buzzing noise when hitting the hazards
I think this is the wrong section so i moved it, please delete this post
