janfdg76
- August 29, 2013
- Ford Explorer 2006
My A/C blows air only at the back seat area, feet area, and the defroster area. It does not blow on the circular vent on driver, center, and passenger.
However it does blows cold air and I can hear the blower or fan working, especially when it is on MAX AC.
One of the thread says something about a white plastic blend door actuator. I checked this and it works. I learned that this is controlled by the temperature knob.
I also checked that metal bar that connects to a small round plastic. This works because it moves when I switch it to blow air to feet area.
Some says about vacuum reservoir or vacuum lines. I do not know where this is.
What else could be the problem? It's like something is blocking the air at the front vents.
