Ford Explorer 99 transmission error codes | Ford Explorer Forums
arty182
1999 explorer
Hi everyone i am new here :)
I just brought a explorer and it suffering from a few codes i found when i done a scan,
P1747 Electronic Pressure Control Solenoid - Short circuit
P1743 Torque Converter Clutch Solenoid Faulty
p0750, p0755, p0760, p0765 to my understanding are solenoids malfunctioning.
Would this be the wiring harness i also noticed when the car is switched on their is a lcd screen on the instrument cluster under the speedo that is blank i dont know if it should display the P R N D 2 1 and highlight the gear its currently in would that also suggest its the wiring harness from the trans too the computer.
Im not sure on this but whats your suggestions and thoughts?????
With that many transmission related codes, I would say you have a wiring harness issue.
Perhaps a wire loom broke loose and the harness melted on the exhaust.
Or maybe some one did some work recently and damaged it.
Does it drive?
It is also possible that the PCM is faulty.
