rtedburke
- March 3, 2004
- Columbia,SC
- 1999 Explorer
I purchased a 99 Ford Explorer about a year ago (4/03) with 104,000 on it. I noticed the transmission had a little difficulty changing arount 30mph. I took it in and had transmission service. Within a 150 miles, the OD light started periodically coming on. It is now 10 months and 7,000 miles later and the above is more frequent. When the OD light comes on it has also has difficulty going up hills from dead stop. Manually changing the transmission into 1 or low and truck takes off fine. Also, when OD light comes on going 60 mph, it shakes a little. If you pulling over and switch the ngine off the OD light goes off and does not come back on and everything seems OK.
Thanks for any help you might have. Problem, Cost of repair, rebuild/replace, recommended transmission shops etc.
