Ford Sport Trac shifting problem | Ford Explorer Forums
dannycaudill
2007 ford sport trac
I have a 2007 Ford Sport trac that has a hard shift problem
when you come to a complete stop it has a hard bump like shift just before it comes to a complete stop.
It also has a problem when traveling at a low speed with the Tork Converter chattering
you can feel a small viraberation and at the same time the rpm guage will go up.
you can maintain the same speed and this condition will come and go.you don't notice it at higher speeds
Welcome to the forum.:chug:
None of what you described sounds good. If the fluid level is correct, it's likely that you're looking at a rebuild.
