2010 sport trac shifts to reverse but slips under power.
Chris A.
Ironwood, MI
2010 Explorer Sport Trac
Hello all,
Recently my '10 sport trac (the 4.0l engine) started acting up when in reverse. It shifts into gear fine and it rolls backward in gear fine (on flat ground when I release the brake it begins rolling backward like it's in gear) but when I try to give it any gas it slips and doesn't provide any power, almost like it does when the traction control comes on and cuts power to the wheels when that system engages. I'm really hoping someone knows something that I can try before having to replace the transmission out right. All the forward gears work fine without any unusual noises or shifting problems that I can tell. Any insight would be greatly appreciated.
JK080
Transmission Moderator
Staff member
Moderator
North Ga
05 F250 6.0
With the 4.0 you should have the 5R55S transmission, this transmission is known for reverse problems. Most of the time it has to do with the low/reverse band, its either the band is broken or the band material has come off.
Only thing to check before having to pull it out is the servo that controls the band, you can get to it when you remove the pan. I rarely see any issues with this servo so dont get to excited but you should be able to check the band at this point just to see if it might be broken.
  • Like
Reactions: imp
Chris A.
Ironwood, MI
The main question I have is would it be a better idea to do a rebuild kit with the band and everything else or just replace the transmission once all is said and done. I dont really have the tools or the know how to do it myself and be confident in my work.
JK080
Staff member
Moderator
North Ga
05 F250 6.0
If you are unable to rebuild the transmission yourself I would recommend a transmission shop that can rebuild it with all the updates this transmission needs to work like it should and gives you a good warranty.
R 2009-2010 6R80 Leak Transmissions & Transfer Cases 3
D 2010 explorer transmission swap Transmissions & Transfer Cases 0
M P0713 2010 Eddie Bauer 4x4 Transmissions & Transfer Cases 4
EGruner 2010 Explorer 4412 TC noise diagnosis help needed -video Transmissions & Transfer Cases 7
C 2010 Explorer Neutral and Reverse swapped Transmissions & Transfer Cases 0
C 2010 Explorer Solenoid Block plug wiring Transmissions & Transfer Cases 2
S Harsh Downshifting around 25 MPH -> 2010 Explorer XLT Transmissions & Transfer Cases 4
D 2010 ford explorer intermitantly will not shift. Transmissions & Transfer Cases 0
S 2010 Rear Diff Oil Transmissions & Transfer Cases 1
I 2010 transmission slip Transmissions & Transfer Cases 0
V Which tranfer case in 2010 Mountaineer? Transmissions & Transfer Cases 0
C 2000 ford explorer sport clutch hydraulic line problem Transmissions & Transfer Cases 2
M M5R1 clutch reccommendation (93' Sport) Transmissions & Transfer Cases 0
0 2007 Sport Trac 4x4 a really weird acting transmission Transmissions & Transfer Cases 13
M Help Please: Parts difference from Gen 1 and Gen 2 sport Transmissions & Transfer Cases 4
J 05 sport trac 5r55e R/OD ,D sometimes work? Transmissions & Transfer Cases 4
R 02 sport trac missing 1st and reverse Transmissions & Transfer Cases 1
B 03 Sport Trac Transmission Problem Transmissions & Transfer Cases 4
B 4x4 issues - 1999 Sport AWD 4.0 SOHC Transmissions & Transfer Cases 1
K Raptor trans in an Ex Sport Transmissions & Transfer Cases 2
C Is the Sport Trac transmission different from other Explorers? Transmissions & Transfer Cases 1
vroomzoomboom 2000 sport p0720 Transmissions & Transfer Cases 5
B '95 Sport Transmissions & Transfer Cases 0
B '95 Explorer Sport 4R55E Transmissions & Transfer Cases 2
K 2003 ford explorer sport xlt slipping in drive/reverse Transmissions & Transfer Cases 1
M HELP!! Lost All Gears in Sport Trac Transmissions & Transfer Cases 13
C 98 sport shifting problems Transmissions & Transfer Cases 0
M 2000 Explorer Sport 4.0 SOHC 5R55E Won't Upshift Transmissions & Transfer Cases 16
J 2002 Ford Explorer Sport - Potential Transmission Problems Transmissions & Transfer Cases 1
P 99 exp. sport trans. slip Transmissions & Transfer Cases 0
G 2003 explorer 4 door xlt sport Transmissions & Transfer Cases 0
C 5R55E in 2001 sport trac Transmissions & Transfer Cases 2
9 2000 explorer sport 2wd plans Transmissions & Transfer Cases 0
Mike65 99 Explorer Sport O/D light flashing. Transmissions & Transfer Cases 8
D Transmission Leak 98 Explorer Sport?? Transmissions & Transfer Cases 2
S 2001 Explorer Sport - No reverse Transmissions & Transfer Cases 3
J 1999 explorer sport 4x4 speed sensor - Need photo Transmissions & Transfer Cases 0
D 2001 Explorer Sport Transfer Case Transmissions & Transfer Cases 2
1 2002 Sport Trac transmission doesn't want to go forward. Transmissions & Transfer Cases 2
S p0741 2001 sport trac Transmissions & Transfer Cases 3
F 2000 Explorer Sport, Trans Case Broke Transmissions & Transfer Cases 2
B 01 exp. sport 4x4 Transfer case swap Transmissions & Transfer Cases 5
V 2002 Explorer Sport Trac Transmissions & Transfer Cases 0
F 97 Sport 4X4 Transmissions & Transfer Cases 1
D 2004 Explorer Sport Code P0732 Transmissions & Transfer Cases 1
B Front gear/diff interchange `96 Exp vs `04 Sport Trac? Transmissions & Transfer Cases 0
S 2003 Explorer Sport with 5r55e, No 3rd Gear Transmissions & Transfer Cases 2
B 99 sport Transmission Transmissions & Transfer Cases 1
B 01 Sport Trac 4x4 tranmission leak Transmissions & Transfer Cases 0
Z 2002 sport trac hesitates in drive Transmissions & Transfer Cases 1
Similar threads
