Boss 338 Gray $145
18x8 5x4.5 +2mm 4.517" bs Ford
18x8 5x4.5 +14mm 4.989" bs Ford
I have my option of both and would like to run a 265/60/18 tire. i personally believe the rim with the 4.989 backspacing will work out better on my vehicle as it will only push the rim .48" inward over the stock rim and keep the .52" torward the face (outward)
I'm running no lift and currently have my TT set at the factory called for ride height with a lil rear spring sag that is soon to be fixed.
My 2nd question is,, which trucks have a harder time with rim fitment, the 4x4 or the 2WD's
Thanks,
Brad M
2000 Limited
