Found at the bottom of my Ford Explorer transmission pan. | Ford Explorer Forums
hoorawflyguy
Cape Cod, MA
2002 Sport Trac 4x4
Hey guys, I found these three metal pieces at the bottom of my transmission pan today. Dose anyone recognize them. I don’t want to say it, but they look like bearings to me. Just wanted to check and see if anyone else could shed some light on them. it's a 2002 ST.
Good catch, BrooklynBay.
How lucky can you get, Hoorawflyguy.....:D
Same thing happened to me when I dropped my pan...Scared me for a minute, then I noticed about a dozen more of those on the gasket, and saw a few were missing. Whew!:chug:
Tell me about it. I was in panic mode yesterday.
Thanks BrooklynBay, that's the response I was hoping top get. ;)
I pulled my old gasket out of the trash and it did have three pieces missing. :)
Rattle in the transmision
I have a rattle in the transmission after just AAMCO serviced it. I wonder if Ford has these pieces in all of their transmission gaskets, and if that's what I hear rattling. I have a 2002 Explorer E.B. 4.6 V8. Any input ?
How much oil takes when you replace just the filter on a 4R70W?
I am getting ready to do this first time and I want to know in advance. Castrol Mercon V can it be mixed with whatever is inside?
Rookie Error
Another great post. Just wish I read it yesterday.
I had a radiator failure which has caused me to drop the transmission pan and flush the oil.
I had read that the pan contains a magnet to stop filings going back through the transmission. So on discovery of the little metal pieces pictured above I thought they had something to do with that. so left them in the pan.
Thankfully I have still not yet refilled the trans with oil. Should I go to the effort of removing the pan and getting these few pieces out, or would they be heavy enough to sit harmlessly at the bottom??
Thanks for any input. (other than the ones that will just laugh) ;)
:exp:
Hi, thanks for the prompt reply.
But I think you misread what I was seeking advice on.
I did clean the magnet.
what I left in there was a few metal pieces from the old gasket..
Should I pull the pan back off or do you think they will sit harmlessly at the bottom.
Cheers.
I'd take 'em out if it were me.
Whew!!!! What a sigh of relief, I just dropped the pan and changed the filter and fluid on my 98 Explorer and found 6 of these in there and was just fixing to post them up to see if anybody knew what they were. I knew they were not magnetic but did not feel like aluminum either and was fearing bearings as well! Thanks for a great forum and being able to find answers so quickly. I was really worried even though the transmission is shifting well.
yeah it seems to be a common thing with this car. Expect the unexpected.
I ended up dropping my pan to make sure I removed all these pieces of metal. Turned out to be a hidden blessing as I realised the filter I fitted was missing the two O rings, meaning there was no tight seal for the trans to suck oil up from the bottom of the pan. this could of been catastrophic if it was left over a period of time.
so here's my tips for successful explorer transmission pan drop:
1. syphon as much of the oil as possible from the dipstick tube. will be 2 less litres you spill on yourself later.
1.5 lift the car as high as possible for ease of access.
2. if yours has one of the exhaust pipes under the pan, the drive shaft at the transfer case WILL HAVE TO be disconnected. easy to do. six small bolts and slide plates away from each other.
2.5 remove pan and filter . fit new filter WITH O rings installed.
3. use degreaser to clean the pan, bots and transmission edge. Ensure any trace of the old gasket/sealant is removed.
4. once everything is clean and dry, apply thin layer of gasket maker to pan edge. place cork gasket on, place bolts trough holes to ensure gasket is perfectly alligned.
5. once dry enough (20-30 min has passed, bolts can be taken out and pan can be replaced.
6. hand tighten bolts starting from the centre bolts and work your way outwards.
7. one resistance is felt by wrench only go another quarter turn or so. again start at centre bolts.
8. replace drive shaft.
9. drop the car. add oil until at level required. done.
great video series on ehow on how to install cork gaskets.
my first uneducated attempt was embarrassing and leaked badly. second was like a pro.
lining up gasket and leaving to dry, plus DO NOT OVER TIGHTEN BOLTS, you'll be fine.
I dobt those little pieces of gassket are going to rattle in the trans. pan enough to be heard with the engine running, swishing in the fluid mind you.
I think the rattling you heard may be the cat. converter breaking apart inside. Withe engine off and cold, try banging on the converter with your hand and see if your hear any rattles.
Good point. I just thought if the fluid was low enough they might.
So here's what happened. The tranny oil pan is loose. Oil all over the place. It was making the cat smoke up.
Previous owner says I have to tighten up the bolts periodically. It's just old.
The noise: turns out it is the muffler, the main muffler down toward the back end. When I give it a big smack it makes the same sound.
Not much I can do about it. Doesn't seem to be anyplace associated with a bolt.
Better get a new gassket for your tranny pan, soon. The rubber one I got for my 5r55e (filter and gasket) worked real well, no leakss and didnt have to retighen the bolts, nor should you. The key to a leak free steel oil pan is to make sure the sealing surface is flat.
