fox shocks | Ford Explorer Forums
fox shocks
moreash14
2005 explorer sport trac
does anybody know if the 2.0 performance series shock will fit our truck
Best bet would be call Fox and tell them you have a sport trac and they will give you a part number for the ones that are the proper length. I haven't seen anyone on here with regular Fox shocks. Only a couple with coil overs
you have to get the 5" travel with stem and bar pin bushing mounts up front and bar pin and bushing mount for the rear. check out my registry
^^Local Fox expert ;)
never seen them with the top pin mount yet, got a pic Shooter ?
cause that would sure change the coilover route for alot of people,,
as in no more custom mounts ,
well it probably would differ with the coilover since the whole truck's suspension will be riding on those shock towers. one skinny stem bolt i wouldn't believe would hold the truck up, especially for the abuse that some people give their trucks. thats the reason for brackets and hoops, to distribute the load evenly across the frame with no weak points. but that is my .02 so that is something you would have to ask the shock builder. i ordered mine from nick kellar at orw. as far as valving goes its difficult to dial in for our trucks and if lifted with torsion bars the shocks would hardly extend anyway. atleast in the front. I'm trying to dial in my kings up front and my fox's now. honestly for the money you could get the rancho 9000's with the myride controller and have much more ride quality options to choose from for less than a standard fox shock. you can however get the ride adjusters for fox and kings but they cost around $100+ per shock and thats with a remote resivoir. also the mounts cost around $40 more per shock. sometimes i wish i got the 9000's but i plan to get ride adjusters since i already have the fox's anyway.
I'll try and post pics of the mounts.
thanks I was thinking about the 9000s to or kyb monomax but haven't seen or heard much about them
No problem. I mean for the money you can get 4 rancho 9000's with myride controller for the same price of 2 fox shocks with piggybacks. Even if you don't get the myride controller, you still get the ride adjusters you just manually have to change it instead of using the controller. And that's even less money you would have to spend. Seems pretty cool if you ask me.
yahh I ordered the 9000 today cant wait to put them on :D
