Iceking007
- February 7, 2008
- Edmonton, Alberta
- 1991 Ford Explorer Sport
Hello after recent Recycle Visits I have come accross a fairly decent looking (not that I was looking) F150 Front axel with 4x4 and manual hubs. The Hubs are Crome with Red centre Locking dials; I believe to be std Ford hubs as they are Red and also only twist 90 deg where as Warn I believe twist 75deg. This is an older Ford F150 around early 90's I would estimate it has Ford Electronic Fuel injection on the Intake manifold it is a 6cyl SOHC I belive. They will let me uninstall it and take it home for $25.00 Canadian. Please let me know any info I need... will this fit into my 1991 Explorer 2dr. Sport 4X4? is this a good axel to use in future. What axel is it? Any other parts I will need to take when uninstalling it?? or just the axel? Also I am looking at a 5" lift with cut and turned beems and longer radius arm... will this axel work with that set up?? I will be lifting probably within a year or so and may do the axel then. Thank you!!
