Glen4X4
- June 5, 2007
- Lewistown, Pa
- 2000 XLS
I'm use to the first gen, I use to be able to park on a hill in 4low and the compression of the motor hold it back it had a 5spd. Now with my 2nd gen explorers, (95 and 96). If I put the t-case in 4low and then put it in park it sits still fine, Until I turn the motor off then it jerks forward as if I'm in 4hi or 2wd. I didn't know if it had something to do with it being automatic or because of the setup of the 4405 tcase or because it has that center axle disconnect, I was under the impression that when your in 4wd the front axle is locked whether the truck is on or off, so with that being said, I don't know if thats the issue or what. Most of you are more knowledgeable on this than I am, and I hate that when I turn the motor off it jerks forward, so somethings got to change with the truck if I don't trade it in. One reason I didn't know if it were the transmission is because it don't stay parked by compression of the motor, but then thought some more and didn't think it would be the transmission because didn't think turning the motor off in park would cause an effect.
