Front body mounts | Page 2 | Ford Explorer Forums
Front body mounts
I tried searching once. Nothing. Tried again and bang got it. Now I just need more tools. Any idea how much the bushing, rubber and metal plate costs if I decide to damage it?
Mine were seized up good. So out came the air grinder! Cut the heads off the bolts. I went to a John Deer dealership and got the perfect size grade 10 bolts & nuts, lock washers.They also had a large fender washer that was a perfect match to the body mount. The rubber spacer is actually silicone, and can take the heat you throw at it. Do not destroy this pc! You need it!
I read about the troubles with these mounts, and when we discovered they were froze, it didn't take long to make the decision to cut em off.
If you do manage to get the mount out, you have to drill out the threads to make room for the new bolts. This is a major pita. Use the biggest bench vise you can find. The funnel shaped mount is no fun at all.
