Front CV axle shaft leaking. | Ford Explorer Forums
seankaufman67
Mendota, IL
2005 Mercury Mountaineer
Would anyone know if changing the cv axle shafts on both sides would fix the leaking or is there a seal that needs replaced and not the axle shaft?
There is a seal that would need replaced. Reuse the axle.
Thats what i thought but wasnt sure because I can't find anything on replacing it. Because you can clearly see on both passenger and drivers side that they're shot by the amount of fluid on the cv shafts.
