MSM0075
- April 10, 2008
- 2003 EB
I took a two hour drive in my wifes '02 Mountaineer 4.6AWD for some training class' for work.
On way back smelt something nasty like gear oil. few minutes later smoke was comming from behind.
Pulled over, found out the front differentail drivers side output shaft seal blew out, causing loss of gear fluid.
Upon inspecting vent tube found that upper vent cap was burt/melted. lower plastic was intact. Tube assembly was in the stock location. Not touching or rubbing on anything.
The main question is. Was it melted due to lack of ventalation or was it melted to begin with..
Even with the burt vent tip it was not covering the whole completly to not allow air to escape.
Does the differentail 'gasket' look factory??
Im just curious to see if its been serviced before.
Vehicle has 41k miles on it.
Only other problem I've been having with this car is it choppes/locks while turning tight at slow speeds
Judging by the TSB's i'm guessing its the rear clutch pack. This problem has been going on since we've bought it at 32k miles.
I just thought it was an AWD thing..
