JusTheUsual
- July 7, 2013
- Central NY
- 1999 Ford Explorer Sport
The drivers side is leaking worse than passenger side. Like a few drops every night and don't want to run out of gear oil in differential. I have no sounds coming from front end so I don't think cv axles need to be replaced unless that is only seal which I doubt. I asked couple people and they don't know if seal the cv axle passes through if I have to just take out cv axle and replace seal or if I have to take front differential apart because they don't know about this model/make. Chevy guys...
My front differential bolt to check fluid I have never been able to get out in the 7years having this truck and it even started stripping... So I haven't messed with it anymore. Otherwise I would just keep putting gear oil in and not mess with all of this other stuff. I thought about the magnetic drill bit and drilling new hole and putting bolt in but I don't trust myself on doing that.
Ideas, thoughts on all of this?
