front Differential leaking | Ford Explorer Forums
scubastevesx
WASHINGTON
2006 EXPLORER XLT 4.6
hi my front Differential is leaking where the cv joint goes
in for now i just want to make sure i have enough oil in
there can u guys let me know were the fill is on it.
found the leak after running over of all things a couch cushion
the left a truck in front of me nothing looks are seems bad but
just happened to find the leak under there has anybody had this
issue thanks going to have it looked at later this month
deleted post....sorry.
I am not by my car now, but at the end of the axle shaft there is a sealing ring I believe. That may be your problem. You'll need to pull the axle out.
There should be 2 plugs in the diff, upper one is for fill, lower for draining it. That's what usually is on differentials. The fluid should be to the bottom of the tread of the fill hole.
